what is it..?
- srtdc@aol.com
26 Aug 2025 15:54 #22972
by srtdc@aol.com
what is it..? was created by srtdc@aol.com
I was power washing the underside of a 1986.5 928. These plastic pieces were on the ground[img]file:///C:/Users/steve/Desktop/thumbnail%20(1).jpg[/img][img]file:///C:/Users/steve/Desktop/thumbnail.jpg[/img] Anyone know what these pieces are from or where they go..?
Thanks in advance....
- dr bob
01 Sep 2025 14:19 - 01 Sep 2025 14:19 #22979
by dr bob
928OC Charter Member
Replied by dr bob on topic what is it..?
Looks suspiciously like a plastic disk that fits in the top of the spring/shock assembly. I don't have the PET handy to ID it for you, unfortunately. From memory these were white poly originally, and are used on enough other Porsches that they are a commodity replacement part.
Last edit: 01 Sep 2025 14:19 by dr bob.
- srtdc@aol.com
01 Sep 2025 15:13 #22980
by srtdc@aol.com
Replied by srtdc@aol.com on topic what is it..?
Thank you for your reply...Roger from 928sRU is in agreement.
Is it something that effects the car or should I ignore it?
Is it difficulty to replace?
Thanks again...
Steve
Thanks again...
Steve
- dr bob
01 Sep 2025 19:57 #22981
by dr bob
In my limited experience... Manufacturers seldom put parts on the their cars without a reason. With that spacer ring out, the suspension will bang on full unload/reload.
From feeble memory, you'll disassemble the shock-spring for access. Pretty much the same effort needed for shock replacement. Chances are good the rest of the suspension is at the same age/deterioration state, so maybe this is the incentive you need to bring all that back to new again.
I'm fortunate to have a corrosion-free car so worry none about going after suspension stuff. If you car suffers from corrosion issues, the lower rear shock pins may be one with the bushing in the lower shock eye. Do a test 'twist' on the lower pins after loosening the nut on one end. If it rotates OK in the shock bushing the removal will be easy. Retighten both nuts against each other until you will actually do the work.
Good on you for grabbing the 86.5 car. Best of both worlds with the classic S body and the updated running gear. Congrats!
Bob
89S4
Bob
89S4
- srtdc@aol.com
02 Sep 2025 08:30 #22982
by srtdc@aol.com
Hi Bob,
I'm in complete agreement with you manufacturers, rarely if ever include parts that lack functionality.
That's what puzzling about these pieces. They are plastic, approximate 1/4" in thickness. Doesn't appear structural, or can withstand ANY force, let alone pounding
from the suspension of shock absorbers. I ordered parts from Roger and will compare them to the broken pieces.
Thanks for the kudos on the 86.5. My friend is the original owner, 34,000 miles, always garaged, just power washed the underside. Looks pristine. Among his collection of cars is a 1982 928.
Best,
Steve
Best,
Steve
Moderators: Rich928, billvvOC
