928 s4
  • mark.sheffield
  • Topic Author
  • Offline
  • New Member
  • New Member
06 May 2025 05:56 #22885 by mark.sheffield
928 s4 was created by mark.sheffield
hi all i have 928 s4 no start
cranks
spark to plugs
fule pump running and fuel pressure
ecu good as have running car i swop over
apears no pulse to injectors
last autum car started but stored out side over winter
any ideas
07 May 2025 07:18 #22887 by NickTucker42
Replied by NickTucker42 on topic 928 s4
Sorry for your troubles..
When you say you swapped the ECU, which one did you swap as there are 2 of them.  One is the LH which has a well documented failure mode due to a daughter board cracking over time, and there is the EZK.  LH is for fuel, EZK is for Spark.
  • mark.sheffield
  • Topic Author
  • Offline
  • New Member
  • New Member
08 May 2025 02:41 #22888 by mark.sheffield
Replied by mark.sheffield on topic 928 s4
thanks for the reply
the lh unit i have spark at plugs not getting fuel
20 Jul 2025 19:22 #22956 by Rich928
Replied by Rich928 on topic 928 s4
This document may assist you to understand and diagnose your problem.
This attachment is hidden for guests.
