Digital Dash Pod Instrument Panel Problems Intermittently Out Blank
- jetav8r
27 Nov 2021 10:12 - 12 Dec 2021 17:52 #22061
by jetav8r
Digital Dash Pod Instrument Panel Problems Intermittently Out Blank was created by jetav8r
Hi all -
Have 1989 S4. Excellent condition but not driven that often (which I know, is not great for these electric jigsaw puzzles).
Instrument panel has started randomly not working correctly. Seems obvious to be a bad connection. My inclination is that it has a bad ground. Symptoms :
- Can hit a bump all starts to work
- If I turn on fog or headlights light some things start to work (like dash is getting ground thru other things turned on)
- Turned lights on yesterday everything started to work except volt meter.
- when in blank mode there is a weird buzzing coming from the fuse panel. Like a relay is not happy. Have not pin pointed this location yet
- Have pulled and cleaedn fuse #5 (pod diagnosis) and fuse #24 (pod diagnosis)
- Have tried to jiggle wires behind dash.... but not a lot of access there.
MY QUESTION IS:
Have not put a lot of research into this yet. Does anyone know how the dash is grounded? Is there a main connector to the POD and if so how to access it.
Any input here will be appreciated and save me some time wading thru manuals, etc...
MY QUESTION IS:
Last edit: 12 Dec 2021 17:52 by jetav8r.
- Rich928
08 Dec 2021 22:35 - 08 Dec 2021 22:36 #22074
Replied by Rich928 on topic Digital Dash Instrument Panel Problems Intermittently Out Blank
I don't have a simple answer for you. Number one, start with a charged battery (or replace if old) and clean the positive cable (and the multiple attachments to the positive) and ground strap. The ground strip is covered with plastic, be sure that corrosion hasn't crawled up under the plastic - replace if necessary.
It may be that a plug to the instrument board has corrosion. Removing the plugs and cleaning them might be the first step.
The factory workshop manuals can be downloaded at www.ligeti.com/928/
Look for the 1989 928 wiring diagram, sheet 4 illustrates the wiring.
Last edit: 08 Dec 2021 22:36 by Rich928.
- jetav8r
12 Dec 2021 17:51 #22082
by jetav8r
Replied by jetav8r on topic Digital Dash Instrument Panel Problems Intermittently Out Blank
Rich -
Thanks for great tips:
All those things are good.
Good battery, everything else in car is fine.
I have every doc imaginable for these cars : Pet5 / fiche / wire diagrams / factory manuals ..... etc....
It seems clear to me connection to dash pod is "dirty"
So I guess my question is:
How hard to get to the back of that? I also have some backround lights out on it..
Anyone fixed a dash pod?
- Gary Knox
- Senior Member
18 Dec 2021 09:08 #22087
by Gary Knox
Replied by Gary Knox on topic Digital Dash Instrument Panel Problems Intermittently Out Blank
Here are two references to read. Dwayne's is for an earlier car, and Schocki's is for a GTS:
Dwayne's: rennlist.com/forums/928-forum/424856-pod...r-w-pics-part-i.html
Schocki's: rennlist.com/forums/928-forum/372301-15-...for-an-ok-price.html
Lots of great info avaialble.
- jetav8r
18 Dec 2021 11:35 #22088
by jetav8r
Replied by jetav8r on topic Digital Dash Pod Instrument Panel Problems Intermittently Out Blank
Gary - Great stuff. THANKS !!
Stupid question #1..... Is it likely my '89 dash is more like the GTS setup. It is the early digital dash. That's what I am assuming here.
Thanks again.
Thanks again.
- Gary Knox
- Senior Member
19 Dec 2021 12:33 - 19 Dec 2021 12:35 #22089
by Gary Knox
Replied by Gary Knox on topic Digital Dash Pod Instrument Panel Problems Intermittently Out Blank
The '89 pod and instrument gauges are, as I recall, identical to the GTS (I've owned both model years). The difference is in the access to removing the pod, as the '90 plus cars have airbags, therefore some different fitments below the dash which have to be removed in order to access the pod bolts, etc.
Your pod REMOVAL should be identical to the earlier car 'non-airbag' procedure.
Gary
928OC charter member, former Treasurer
Gary
Last edit: 19 Dec 2021 12:35 by Gary Knox.
Moderators: Rich928, billvvOC
