WIRING DIAGRAM
- morrelli
18 May 2021 15:52 #21886
by morrelli
WIRING DIAGRAM was created by morrelli
REQUIRE 1981 WIRING DIAGRAM , ANY OFFERS, EMAIL MAYBE?
- joejabq
- Premium Member
- Thank you received: 9
18 May 2021 16:12 #21887
by joejabq
Replied by joejabq on topic WIRING DIAGRAM
Sent to your email!
- BloodyFoot
22 Aug 2022 21:58 #22234
by BloodyFoot
Replied by BloodyFoot on topic WIRING DIAGRAM
Joe - This is what I so love about the 928 OC, individuals like you who are willing to share their knowledge. I too am bringing back to life a 1981 and have not yet found a wiring diagram - can you share yours with me please? Email is norristimothye@gmail.com. I started with cleaning the grounding points, but quickly learned that the document I was referencing was for a newer 928 and I did not have all the ground points present in that model year.
Again. many thanks1
Again. many thanks1
- joejabq
- Premium Member
23 Aug 2022 08:14 #22235
by joejabq
Just sent to your email!
- joejabq
- Premium Member
23 Aug 2022 09:09 #22238
by joejabq
Sorry! I'm just seeing this. Do you still need the Wiring Diagram?
- vmd999
04 Dec 2024 13:20 #22787
by vmd999
Replied by vmd999 on topic WIRING DIAGRAM
Hi guys, I dealing a short somewhere in the car is constantly overloading the fuse 23 (Interior lights). Is there a wiring diagram around that would help pin point the issue?
- Rich928
04 Dec 2024 19:20 #22788
Replied by Rich928 on topic WIRING DIAGRAM
Quite often (has happened to me) this fuse blowing is caused by the center overhead lamp being broken and shorting out. Remove the lamp and inspect it. I believe the clock is on the same circuit.
- Zirconocene
15 Dec 2024 18:11 #22791
by Zirconocene
Replied by Zirconocene on topic WIRING DIAGRAM
I have this as a pdf, if you need it. Let me know and I can send you a copy.
Cheers
Cheers
- vmd999
15 Dec 2024 19:55 #22792
by vmd999
Would be great, thank you
- vmd999
15 Dec 2024 20:16 #22793
by vmd999
Oops mine is a 1982
Moderators: Rich928, billvvOC
