What to do next?
- babromovage
21 Nov 2011 19:27 #7058
by babromovage
What to do next? was created by babromovage
I am now three months into ownership and have tucked my car away for the winter. I am trying to plan what to work on next. The 1986.5 I have has 40k on it and basically has had nothing done to it beyond scheduled maintenance via the PO. I am looking for guidance on what I should do next.
Here is what I have completed thus far:
1. Timing belt, water-pump, porktensioner, and all related gaskets and seals.
2. Porken Chip installed Qrings left to do.
3. Valve cover gaskets and all seals and O rings. Had a slight leak.
4. Cam adjusted to -2 degree.
5. Adj. fuel reg. installed
5. Replaced wipes.
6. Hatch Struts.
7. Hood liner.
8. All interior dome light with LED's
9. License Plate light LED's
10. Fixed rear wiper and trunk latch.
11. Manual trans fluid
12. New Tires
13. New Shocks (have but have not installed yet)
14. Treated all leather.
I have to work on the windshield washer next. What other recommendations do you have that I should consider?
Also, I have a slight hum in my driver side rear. Is it possible that I have a bad wheel bearing? Form what I have read these generally do not go bad with low milage. Can you tell me what else it may be?
As usual, I would appreciate any insight you can offer.
Thank You
5. Replaced wipes.
6. Hatch Struts.
7. Hood liner.
12. New Tires
Thank You
21 Nov 2011 19:49 #7059
by the flying scotsman
Replied by the flying scotsman on topic What to do next?
If not already done all fluids.
The hum from the right rear could be the fuel pump.
- babromovage
22 Nov 2011 05:52 #7067
by babromovage
Replied by babromovage on topic What to do next?
interesting. The fuel pump. Is it your opinion as well that it should not be the bearings?
Did all fluids and plugs.
Thank You,
Thank You,
22 Nov 2011 08:12 #7069
The fuel pumps get louder as they age and in my experience the noise increases after the car has been run for a good distance. They also fail like a light switch and given the age of all 928s they should be considered for replacement.
For piece of mind I replace the pump, fuel filter and the metal fuel line between with the correct size copper washers. Job done for another ~20yrs
- babromovage
22 Nov 2011 11:15 #7074
by babromovage
Solid advice...Thank You
- 928mac
- Moderator
22 Nov 2011 15:23 #7076
Replied by 928mac on topic What to do next?
Old fuel lines must be replaced.
There has been more then a few cars that have caught fire
Moderators: Rich928, billvvOC
