fuel pump preasure
  • whcherman
  • Topic Author
  • Offline
  • Junior Member
  • Junior Member
03 Nov 2011 16:23 #6718 by whcherman
fuel pump preasure was created by whcherman
I have a 84 928 s, would like to know if any one knows what the pressure should be. I measured at the fuel filter, and injector rails. It was ~120 psi.
03 Nov 2011 21:51 #6724 by 928mac
Replied by 928mac on topic fuel pump preasure
That seems really high and i do not even know if that is possible from a stock pump.
Could it be that your gauge is bad, the easy way to check is to try with a different gauge (borrow one) and take a picture for us so that we see where the connection is made.
BTW what name should we call you.
  • whcherman
  • Topic Author
  • Offline
  • Junior Member
  • Junior Member
04 Nov 2011 08:28 #6734 by whcherman
Replied by whcherman on topic fuel pump preasure
My name is James, and yes I could try another gauge. But what should the pressure be? the only reference I found was 58 psi and 35 gph.
Thank you
  • whcherman
  • Topic Author
  • Offline
  • Junior Member
  • Junior Member
04 Nov 2011 08:31 #6735 by whcherman
As taking a picture, my profile say's I cannot make attachments.
05 Nov 2011 11:54 #6744 by 928mac
whcherman;6890 wrote: As taking a picture, my profile say's I cannot make attachments.
Stan can you give James a hand.
05 Nov 2011 15:06 #6747 by Kiln_Red
Replied by Kiln_Red on topic fuel pump preasure
Somewhere around 36psi would be ideal fuel pressure on your '84.
  • whcherman
  • Topic Author
  • Offline
  • Junior Member
  • Junior Member
07 Nov 2011 06:29 #6766 by whcherman
I tested my gauges, and they are good. this is how i made the connection.
1. removed fuel line exiting the fuel filter.
2. attached gauge to the fuel filter.
3. turned on pump
4.gauge reads greater than 100 psi
5. this is the only reference I could find
Walbro Part Number: GCL606
Minimum Current: 12 Volts
Operating Pressure: 58 PSI
Minimum Flow @ Outlet: 38 GPH High Pressure
Fuel Pump Location: In-Line
6. the reason i began investigating in this manner, because i blew fuel pump relay. and i wanted to see if this was a indication of a bad fuel filter or pump.
but both appear to be good. new relays will be here tomorrow.
  • whcherman
  • Topic Author
  • Offline
  • Junior Member
  • Junior Member
07 Nov 2011 07:10 #6767 by whcherman
www.autoperformanceengineering.com/pics/gsl391.jpg
this would probably be fuel pump spec's. and with zero flow, which was how i measured the psi. it is over 100 psi. but at 60 psi you have established the required flow rate. I believe, I am a chemical engineer not a porsche mechanic, but learning now for 15 yrs.
07 Nov 2011 10:52 #6770 by 928mac
On the passenger side fuel rail there is a spot to check fuel pressure while the car is running.
This is the normal spot to check pressure so that you can see if the FPR (Fuel pressure regulator) is working right.
I removed my cats so that the exhaust flows better and I ported the heads and I run 56psi. 50 is lots for a stock engine and more is not better in every case.
I hope this helps but it was more then likely just an old relay.
Most on here replace all the relays and fuses just to be safe.
07 Nov 2011 12:29 #6773 by srshaw3
Replied by srshaw3 on topic fuel pump preasure
928mac;6899 wrote: Stan can you give James a hand.
It is a member only privilege. I do not find James listed in our membership database.
07 Nov 2011 12:44 #6776 by 928mac
Stan.Shaw@Excell.Net;6928 wrote: It is a member only privilege. I do not find James listed in our membership database.
Come on James, loosen up those purse strings and send the $28 big ones ;)
If you want the privilege that is. :rolleyes:
  • whcherman
  • Topic Author
  • Offline
  • Junior Member
  • Junior Member
07 Nov 2011 14:26 #6777 by whcherman
where do i send it, must have missed that when i registered.
  • whcherman
  • Topic Author
  • Offline
  • Junior Member
  • Junior Member
07 Nov 2011 14:29 #6778 by whcherman
yes, you are correct. new relays will be here tomorrow. I have already investigate that area on the rail. will measure there tomorrow if the car runs. funny thing it was running fine, I had to change coolant recovery tank, and here I am can't imagine what I could have done wrong on the nuckle buster.
07 Nov 2011 14:54 #6779 by srshaw3
whcherman;6932 wrote: where do i send it, must have missed that when i registered.
If you want to join the club, the application is online at 928oc.org/signup_information.htm You can print and mail, or fill it out online and pay via Paypal.
  • the flying scotsman
  • Offline
  • Platinum Member
  • Platinum Member
07 Nov 2011 16:11 #6781 by the flying scotsman
Replied by the flying scotsman on topic fuel pump preasure
120 psi is wrong.......the WSM states correct pressures and how to proceed page 24-8.....good luck
  • whcherman
  • Topic Author
  • Offline
  • Junior Member
  • Junior Member
07 Nov 2011 19:24 #6784 by whcherman
I tried using pay pal, i wasnt working. I will send it in the mail. or try again tomorrow.
thanks
07 Nov 2011 20:01 #6786 by srshaw3
whcherman;6939 wrote: I tried using pay pal, i wasnt working. I will send it in the mail. or try again tomorrow.
thanks
Curious as to "how" it wasn't working. I hear that now and again, but yet we get many payments via Paypal, including one today. Perhaps there is something I can "fix".
  • whcherman
  • Topic Author
  • Offline
  • Junior Member
  • Junior Member
08 Nov 2011 14:45 #6807 by whcherman
Stan.Shaw@Excell.Net;6941 wrote: Curious as to "how" it wasn't working. I hear that now and again, but yet we get many payments via Paypal, including one today. Perhaps there is something I can "fix".
I will try pay pall again right now, if i have a problem i would another message
  • whcherman
  • Topic Author
  • Offline
  • Junior Member
  • Junior Member
08 Nov 2011 15:31 #6809 by whcherman
Got it done, It was a address problem. sorry
James herman
  • whcherman
  • Topic Author
  • Offline
  • Junior Member
  • Junior Member
09 Nov 2011 09:43 #6827 by whcherman
Please, some one tell me why I cannot open these files
thank you
james
09 Nov 2011 09:48 #6828 by 928mac
whcherman;6982 wrote: Please, some one tell me why I cannot open these files
thank you
james
What Files are you talking about James?
09 Nov 2011 09:58 #6830 by srshaw3
thank you
james
Because the process to upgrade your membership to "member" is a manual one. I just took care of it, you may need to log out and back in.
  • whcherman
  • Topic Author
  • Offline
  • Junior Member
  • Junior Member
09 Nov 2011 19:52 #6839 by whcherman
yes, thanks it works now.
  • whcherman
  • Topic Author
  • Offline
  • Junior Member
  • Junior Member
09 Nov 2011 21:00 #6840 by whcherman
received new fuel pump relay today. after looking at it and comparing to my old one. I see a difference in the electrical schematic. this relay came from vertek, I also checked with autohaus the offered the same one made by kae. although both show a picture of my original. what do you think, should i use it or not? here is the picture. can't attach picture will have to figure this out.
  • whcherman
  • Topic Author
  • Offline
  • Junior Member
  • Junior Member
09 Nov 2011 21:12 #6843 by whcherman
hopefully the image is here.
Attached files [img]media/attachments/6998=784-fprelays.jpg[/img]
10 Nov 2011 12:48 #6858 by 928mac
whcherman;6998 wrote: hopefully the image is here.
Hi James;
yes the picture is there.
Make sure (verify by jumping) that is the fuel pump relay
I need to check on the fuel pump schematic before I can say to much more.
Can you take a pic of the fuse panel and the relay that you are replacing?
BTW I use photo bucket to store my pictures on line. It makes it very easy to post them here as they give you [IMG] links ready to post with.
If you haven’t yet, Google photo bucket and get a free account.
  • whcherman
  • Topic Author
  • Offline
  • Junior Member
  • Junior Member
10 Nov 2011 16:00 #6862 by whcherman
928mac;7013 wrote: Hi James;
the relay, that i am replacing is the one on the left. and yes i jumped and fuel pump runs. the schematic on the right is my concern.
  • whcherman
  • Topic Author
  • Offline
  • Junior Member
  • Junior Member
11 Nov 2011 15:52 #6886 by whcherman
got her done, original relay was still good. fuel pressure on the rail 38psi. Found bad ground on the rear of the head on the passenger side.
