4 post lift?
- srshaw3
I want one that:
1. Can be rolled around.
2. Will fit under a 10’ ceiling
I have started reviewing several, and would appreciate any knowledge, pros or cons, of the many brands out there.
- 928mac
- Moderator
One of the coolest ones that I have used is the Rotary Lift
directory.groundsupportworldwide.com/pro...raulic_Portable_Lift
Its Pricy though because it is the best.
This bring another note: cheap is dangerous. end of story.
anything under $2500 (canadian) 2 post, is cheap
That said the one below dose not have enough info so I can't tell
I found this post but never checked it out.
stcloud.craigslist.org/tls/2213474913.html
www.completehydraulic.com/
- srshaw3
I want portable for a number of reasons, not the least that I don't intend to live here forever.
There are a number to pick from in the 4 post world that fall under $2500 US.
Here are a few:
www.eagleequip.com/page/EE/PROD/LI-SS/GLO-8000
www.harborfreight.com/automotive-motorcy...rage-lift-68481.html
www.northerntool.com/shop/tools/product_200349258_200349258
www.backyardbuddy.com/automotive-lifts/b...000-lb-4-post-lifts/
www.bendpak.com/car-lifts/four-post-lifts/HD-7P.aspx
- 928mac
- Moderator
The 4 post like you have listed all seem to be fairly good quality.
I would pick the eagle as a first choice, but with out the specs on some of them it is hard to compair.
As much as the back yard buddy seemed like it would be a cheap hoist, it also seams like a good pick.
By portable I thought you ment that you could roll it out to the drive way and lift a car 7 feet in the air. That is why I sent you the rotary lift link.
I have used them to lift a trackor trailer truck and you just roll the post up to each wheel and lift the vehical with its own tires.
- srshaw3
A key use I expect will be in the winter when cars are in storage, so one car will sit over another for months.
- 928mac
- Moderator
All of the ones that you posted look fairly safe which should be the main concern.
The harbor one looks good to.
Still If I knew that I wanted to by a quality unit, I would go with a name brand.
It looks like that buddy one has wheels on it and you may be able to stack cars with it.
- srshaw3
www.costco.com/Browse/Productgroup.aspx?Prodid=11288133
He point out this good review of it. I will want the jack plate and caster kit as well.
www.fordmuscleforums.com/other-articles/...dannmar-d7-lift.html
Seems like it could work well for me, I am a Costco member and could pick it up locally to take off the car trailer at my own pace.
- 928mac
- Moderator
Stan.Shaw@Excell.Net;3973 wrote: I was pointed to this one by an engineer who said this was his second choice.
What I looked at when I read this ad was
Spring-loaded safety locks on each column (IMO these can fail compared to the gravity latch locks)
Single safety lock release handle (leaver and button[2 hand] are the standard)
Self-lubricating bearings and cable sleeves (not a plus, grease zerks are a must)
There are a lot of bad points in the review, I wouldn't get it, But
This still may be a good hoist for you Stan, I am just picking it apart for you.
- srshaw3
You like the eagle lift?
- 928mac
- Moderator
Here is the PDF on it
eagleequip.com/pdf/Manuals2/GLO-8000%20I...llation%20Manual.pdf
They just ran a special so you may want to call them.
eagleequipblog.com/2011/02/01/our-best-deal-yet/
- srshaw3
www.derekweaver.com/update/Pro-Park_8_St...s_Product.aspx?id=32
- 928mac
- Moderator
Stan.Shaw@Excell.Net;3989 wrote: And another that is recommended by another car owner, made in U.S. too
Yes its ALI/ETL Certified and they are going for the OSHA
The Direct-Lift Pro-Park 8 Plus looks like all you would need
Its all up to you now that you have a few good ones to pick from.
Size of garage/hight, weight it will handle and safty, cost last but not least.
