Brakes
- sky22blue
16 Jan 2020 18:44 #21102
by sky22blue
Brakes was created by sky22blue
86 928 After driving about a hour ( with moderate braking ) brakes not releasing at all four wheels all four wheels are hot
- Trainer
18 Jan 2020 15:04 #21104
by Trainer
Replied by Trainer on topic Brakes
your brakes are binding. You need a new master cylinder.
- sky22blue
18 Jan 2020 18:01 #21105
by sky22blue
Replied by sky22blue on topic Brakes
Thanks Trainer It doesn't do it all the time. I drove about 45 miles brakes were OK. Drove about 5 miles applying brake 8 -10 times before it started binding. Car has ABS and my left rear speed sensor is defective it is an early 86 and I can't find a replacement. . Engine bay around master cylinder area was very warm.
- Trainer
19 Jan 2020 07:23 #21106
by Trainer
When the washers are getting hard in the master it behaves that way. The problem will be intermittent not constant. Change the master and while you are at it you might as well overhaul the calipers as well. The age of the car suggests this is necessary.
Moderators: Rich928, billvvOC
