Fuel pump question
- new928
- joejabq
- Premium Member
- Thank you received: 9
- new928
- Rich928
- joejabq
- Premium Member
Rich928 wrote: We don't know the decision making process for Porsche. The 1978 - 1979 CIS cars had two Fuel pumps. Later, some cars had two, some didn't. My 1993 GTS has two fuel pumps. There are theories that for hot climates the in-tank pump helps reduce the chances of vapor lock ... we don't know.
That's my understanding as well. Everything that I've read hints that the two pumps are to avoid vapor lock when running hard in hot locations.
I'm going to dig into my CIS this summer. One of the tests is the fuel flow rate with one or two pumps. I'll be sure to report what I find.
- new928
Being in Washington state we at least don't get the heat very often up here. I'll probably lean towards the single pump set up for now unless I come across a reasonable priced option for in the tank. Just picked up the car on Saturday and haven't had a chance to start going at it.
- new928
- joejabq
- Premium Member
Nice looking 928!new928 wrote: So I finally had some time to get the car up on ramps and take a look underneath the back end. The previous owner had removed the tank and cleaned it out. I've found some pictures online of the fuel system but still don't understand it a whole lot yet and I don't want to start putting things back yet. Do the 2 pumps work in unison all the time or does one work while the other doesn't depending on the fuel in the tank? I see a large rubber fuel hose that goes from the external pump up and around the passenger rear wheel well and there seems to be a filter attached in the wheel well. I'm assuming this is a stock setup? Then at the top of the tank there's a fuel line that runs straight under the car towards the engine.
Ahh, I did this job on mine last year.
I'm pretty sure that Both pumps run at the same time, but I didnt put the inside pump back in. What you describe is what I have on my 79. There's an accumulator in the wheel well too that keeps some fuel line pressure so the car starts quickly. The top line is the fuel return line coming out of the fuel distributor (if I remember right).
Roger (928sRus) sells a fuel line replacement set. You might consider changing the lines now since everything is out and because there's nontrivial pressure in the lines.
When you get to the old lines in the engine compartment, it's really hard to take off the coupling next to the firewall so Roger suggested that I use a dremel and cut the line and leave the coupling In place. Then attach the new line back on the coupling. Hope that makes sense! Have fun! I may some pics in my post. (Joe's 79)
- Balz
- new928
Ok, so this is starting to make a bit more sense to me. I'm thinking I can add one of these (in the picture) into the tank instead of the pump. That goes from the tank to the external pump and then through the filter (I might have that backwards) , then to the accumulator in the wheel well towards the engine. Then there is a line that comes from the engine back to the top of the tank in the sender unit?
- joejabq
- Premium Member
new928 wrote: Great point Balz. When I get to the point of adding fuel to the tank I'll definitely do that.
Yes, you got it! Just to be perfectly clear, working from the tank forward, the rubber hoses part of the lines that you described, eventually connects to hard lines going forward to the engine compartment. The rubber hoses pick up there next the the firewall. All of these rubber hoses are of a particular rating for the pressure. You can't use just generic rubber fuel lines! Just get the kit from Roger. It has the right grade hoses already cut and clamps.
If you have any questions, just post and I can send you pictures from my 79.
When you get it all put back together, you can locate the fuel pump relay and the right terminals to jump so you can test that power is going to the pump(s) properly check for leaks and such without having to crank the engine.
BTW, I had to replace my sending unit too because it was frozen. hopefully yours works, but don't be surprised if it doesn't.
Martinss shared this with me when I started and it was incredibly useful:
"I find the pictures in PET invaluable Joe. Mostly I go to the Autoatlanta site and 'Shop hard parts' for the correct model year; yours would be: www.autoatlanta.com/porsche-parts/928-78...orsche_928_parts.php
The full PET Catalog is available in PDF for each model ( www.porsche.com/canada/en/accessoriesand...ginalpartscatalogue/ ) and I have it saved locally on my computer, but while it is more complete, most times the Autoatlanta site is more convenient."
- P928Jeff
