IP address request during registry log in
- 928mac
- Moderator
29 Oct 2014 09:36 #17699
IP address request during registry log in was created by 928mac
This is the drop down message that I get
(To view this page, you must log in to area “geoip2” on geoip-ipv4.maxmind.com:443.)
I googled it and it seems to be an IP tracking system but it is asking me for a user and password.
Anyone else have this issue.
BTW I am using a Mac Book Pro if it matters.
- 928mac
- Moderator
29 Oct 2014 09:58 #17700
Replied by 928mac on topic IP address request during registry log in
On a second problem.
I seem to be registered twice.
I would like to have my 928macd profile changed to 928mac
both exist
then 928macd can be deleted
Thank you
both exist
Thank you
- 928mac
- Moderator
29 Oct 2014 10:00 #17701
both exist
Thank you
both exist
Thank you
- billvvSU
- Thank you received: 13
29 Oct 2014 11:27 - 29 Oct 2014 11:57 #17702
by billvvSU
Replied by billvvSU on topic IP address request during registry log in
You should be aligned now; Please check and let me know.
I believe the maxmind registration requirement is a mobile device anomaly. Still checking.
Last edit: 29 Oct 2014 11:57 by billvvSU.
- mm928
- Moderator
- Thank you received: 9
01 Nov 2014 13:35 - 01 Nov 2014 13:37 #17715
Replied by mm928 on topic IP address request during registry log in
Same problem here as Mac - asking for a login to the registry page, and my current valid login to the Forum (which obviously works:)) does not suffice. I also had a different profile before Stat_928, it is now mm928. But I have been in the registry before,,, maybe it was before I changed the profile, I do not remember.
Anyway - cannot login to the Registry right now.
thanks
MM
thanks
MM
Last edit: 01 Nov 2014 13:37 by xmm928.
- billvvSU
01 Nov 2014 14:39 #17723
by billvvSU
Hey, MM
Sorry you're having problems; We've been trying to align the Forum db with the Membership db and Registry db. The hardest to change is the Forum db because we need to change the records of each post. RIght now, you have two accounts on the site and in the forum; mm928 and Strat928, which makes it even harder. Your Membership is under the Strat account. I do not see a Registry entry under either account - let me know the title of the Registry entry if you have one.
So.... I believe we can combine the two Forum accounts under the mm928 username - I wrote a program yesterday to do that for about five 'orphans' and it seemed to work pretty well. Do you want me to try and combine them? What I'd like to do is move the mm's to the Strats, then change the username for the Strat back to mm along with the mm email, and finally, ask you to log on to the new mm account using the old Strat password. I can reset the password if necessary.
Sound OK?
Sound OK?
- mm928
- Moderator
01 Nov 2014 21:53 #17724
No problem, but I thought we had already combined both (Derrick). And I have put my car in the registry so at least one should work...
But go ahead and combine,,, leaving mm928 as the current account. If you need to change the password just let me know,,, but currently that one works (for mm928) for sure. I want to move from strat_928.
regards,
Mike
regards,
Mike
- billvvSU
02 Nov 2014 18:11 #17727
by billvvSU
Mike,
You should be good to go now after some shenanigans; let me know if you have any more problems;
Bill
Bill
- 928mac
- Moderator
Moderators: Rich928, billvvOC
