- Thank you received: 9
Suggestions - Spider Emblem attach
- mm928
- Moderator
11 May 2013 19:45 #14678
Suggestions - Spider Emblem attach was created by mm928
Hey guys and gals,
I am finally getting the Shark back from the engine pull on Monday. I have a brand new metal Porsche badge to affix to the Spider. The Spider is powder coated so it is smooth. I have to cut off the tines on the back of the emblem (hood emblem) then glue, epoxy it to the nicely smooth finish of the Spider main body.
So - what to use?
JB Weld
Gorilla Glue
Adhesive made for auto/marine
Adhesive made for hi-temp
Super Glue Gel
Hi-temp Silicone sealant (ATV)
etc.
And should I seal the edges as well with something clear? or just leave it if there is a tiny gap? I do not want it to look goopy.
What have you had success with or summize is the correct thing to use? I assume it is never coming off unless it is re-powder coated, but I would not want to tear up the emblem or body trying to get it off. On the other hand I do not want to open the hood one day and see it gone!
The thing that worries me is the smoothness of the Spider body and the relative un-stickyness of the back of the emblem since it is some kind of pot metal.
Any ideas before Tuesday????
thanks
So - what to use?
JB Weld
Gorilla Glue
Super Glue Gel
etc.
- Kiln_Red
- Moderator
- Thank you received: 10
12 May 2013 02:56 #14679
Replied by Kiln_Red on topic Suggestions - Spider Emblem attach
I used windshield urethane once. I was able to get the emblem on flush with little cleanup effort required. I just wiped off the unwanted urethane with lacquer thinner on a rag while it was still wet. It would be a major PITA to remove now, but it could be done with a putty knife affixed to an air hammer. If one thing is for sure it's that it won't be coming off by surprise.
- mm928
- Moderator
12 May 2013 17:19 #14686
Replied by mm928 on topic Suggestions - Spider Emblem attach
Good one Austin, had not thought of that!
- Ducman82
- Senior Member
13 May 2013 13:59 #14695
by Ducman82
Replied by Ducman82 on topic Suggestions - Spider Emblem attach
used simple 30min epoxy from the auto parts store. works GREAT
- mm928
- Moderator
14 May 2013 17:14 #14720
Ok, so it looks like I am overthinking this then huh?
Looks like lots of things work fine.
thanks guys....
thanks guys....
- 928mac
- Moderator
15 May 2013 18:49 #14754
Replied by 928mac on topic Suggestions - Spider Emblem attach
I use an automotive contact cement for most stick on items. talk to your auto parts place.
- mm928
- Moderator
15 May 2013 18:50 #14755
Thx Mac - we ran into a last minute broken power steering line,,,,,on the way from Roger and hope to have the Shark back Saturday. Then I can decide what to use!
- Normy1
- Senior Member
19 May 2013 20:21 #14814
by Normy1
Replied by Normy1 on topic Suggestions - Spider Emblem attach
I powder coated my spider and used black high-temp RTV to hold it down.
N
N
- mm928
- Moderator
22 May 2013 21:14 #14850
Thx Normy
Moderators: Rich928, billvvOC
