Thinking of pulling the engine
  • snowglobe
  • Topic Author
  • Offline
  • Junior Member
  • Junior Member
04 Mar 2013 20:29 #13785 by snowglobe
Thinking of pulling the engine was created by snowglobe
I took my 928 to the shop on Friday due to a coolant leak. I had purchased parts to refresh the fuel lines, PKT, TB, WP, and am looking to do more, but I've done nothing with them. Looking to finish equipping my garage.
I saw a thread on custom engine mounts on rennlist and am considering the Jegs stand mentioned in the first post:
forums.rennlist.com/rennforums/928-forum...-stand-adapters.html
www.jegs.com/i/JEGS+Performance+Products/555/80059/10002/-1
Still no idea about a hoist, although a google search turns up many. Any recommendations?
My liftbars arrived last Friday, I have four 12 ton jack stands and a Costco 3.5 ton jack.
I'm wondering what else to get in order to safely remove and work on an engine (and put it back in! arg), or do a TT service on the 928 (to put in Constantine parts).
--Jim
04 Mar 2013 22:50 #13788 by mm928
Replied by mm928 on topic Thinking of pulling the engine
Well - if you are not in a big hurry, I am pulling mine likely this weekend. My friend has the equipment. I have the same stands, bars and lift jack from Costco that you do!
I will be glad to let you know what he uses as a hoist when I get over there as well as the engine stand. I have an 83 US auto, so our engine bay should be pretty similar.
06 Mar 2013 11:27 #13806 by wallyp
Replied by wallyp on topic Thinking of pulling the engine
I would suggest a heavy-duty hoist with foldable "legs". These take up much less room when not being used.
An adjustable bar that balance engine weight and allows tilting the engine is helpful.
You need a really good engine stand - the 928 engine is heavy and top-heavy. Since it is really nice to be able to rotate the engine on the stand, a gear-driven rotation is expensive, but makes it easier and safer to rotate the engine to work on the bottom.
06 Mar 2013 12:07 #13807 by Kiln_Red
Replied by Kiln_Red on topic Thinking of pulling the engine
For curiosities sake, is there any specific reason or maintenance that you have in mind that requires removing the engine?
06 Mar 2013 18:59 #13812 by 928mac
Replied by 928mac on topic Thinking of pulling the engine
Both the engine crane and the engine stand that I bought have folding legs. it saves a lot of room and headache.
07 Mar 2013 00:40 #13818 by xstepson
Replied by xstepson on topic Thinking of pulling the engine
wallyp;14164 wrote: I would suggest a heavy-duty hoist with foldable "legs". These take up much less room when not being used.
+1 on all this, but the adjustment bar really makes the pull and reinsertion of the engine go smoother.
Buy at least a 1000 lb engine stand. They generally have a wider and heavier base. Nothing worse that turning over the engine on the stand and it toppling over.DO NOT ASK ME HOW I KNOW THIS.
I have calculated that 8 quarts of oil on your garage floor seems roughly enough oil to cover the state of Rhode Island at least a millimeter deep.
  • snowglobe
  • Topic Author
  • Offline
  • Junior Member
  • Junior Member
07 Mar 2013 11:33 #13822 by snowglobe
Replied by snowglobe on topic Thinking of pulling the engine
I'd like to remove the engine because I'm a newbie to engine maintenance so nothing seems too extreme. That said, the engine compartment seems awfully tight. I'd like to install a PKT and water pump and, if doing it alone, imagine that and anything else would be easier with the engine out. I'd still have to get it back in, of course.
I realize this could become a 6 month project after I take it out, but then I could also do a lot of cleaning, replace engine mounts, examine all the wiring and tubes, etc.. Actually, I have the strange, OCD fantasy of stripping this car to the bone, removing and rebuilding the engine and transmission .... Compared to that, taking the engine out to do some basic maintenance is a more reserved plan.
Are there any specific models of hoist and stand you would recommend? Jegs also sells a one ton hoist, but it didnt come with a bar. I'd like to be able to re-use the equipment for my SUV, so large and heavy duty (and folding or bolted) are desirable.
07 Mar 2013 21:23 #13832 by Kiln_Red
I would recommend this engine hoist. It folds up and comes with a load leveler as has also been suggested.
Here is an engine stand that looks safe for the 928 engine. Can't personally vouch for this product as it is a different model from mine, but I wouldn't be afraid to use it.
John is absolutely right that the right engine stand is crucial. An I-type stand is dangerous for an engine as broad, tall, and stout as ours. You need the H-type as I recommended. I wouldn't pull the engine for a timing belt job, but I admire your enthusiasm and am sure that you'll find that it was worth it to do once it is reinstalled. Lots of otherwise tricky maintenance becomes childs play with the engine removed.
The following user(s) said Thank You: snowglobe
12 Mar 2013 13:44 #13860 by wallyp
The real down-side of pulling the engine is that the WYAIT list gets huge!
The real up-side of pulling the engine is that when you finally do get thru with it, there will be great feelings of satisfaction, pleasure and pride.
Don't get in a hurry...
12 Mar 2013 20:52 #13864 by mm928
Mine is coming out this Saturday !!!!...I am excited...
