Link to keeping 928 alive
- 928mac
- Moderator
Here is a link to a good thread that needs everyones 2 cents.
Don't forget to bring your opinions back to this board.
Thank-you 928 Members
forums.rennlist.com/rennforums/928-forum...esident-longish.html
- Kiln_Red
- Moderator
- Thank you received: 10
- 928mac
- Moderator
I really enjoy this. To much maybe as the car dose not get worked on while I am sitting on my lap top :rolleyes:
- Kiln_Red
- Moderator
lol! I know precisely what you mean, Brad. The computer will, no doubt, intervene on automotive projects quite often. Your contributions here are very valuable to the club, by the way. Thank you so much for sharing your enthusiasm here with us at the 928OC board.928mac;690 wrote: I agree Austin that we don't need bad apples and that its not about the money. I am here to gain and gather info and in return I give as much time and info back to the forum as I can.
- monte928
- Kiln_Red
- Moderator
monte928;880 wrote: i injoy reading your info. and it has helped me alot. I am a new 928 owner and i need all the help and info. i can get thank you !
Thank you! Let us know when we can be of service to you. It's a very rewarding feeling to know that we can help fellow 928 owners however we can.
- srshaw3
KilnRed;881 wrote: Thank you! Let us know when we can be of service to you. It's a very rewarding feeling to know that we can help fellow 928 owners however we can.
The other way of looking at it, is that it is refreshing and perhaps encouraging, to find others similarly enamored with the 928.
I still have my the first 928 I purchased in 1989, and the addiction has only gotten worse!
- 928mac
- Moderator
Stan.Shaw@Excell.Net;882 wrote: The other way of looking at it, is that it is refreshing and perhaps encouraging, to find others similarly enamored with the 928.
Hey Stan, do you have a recent picture of your 1st 928 so we can see how it developed
- srshaw3
When it is reassembled, at some unknown point in the future, it will likely have a stroker motor, GT transmission, with associated upgrade parts.
I hope to at least put the bored block on an engine stand and do a test fitment assembly in the next few months, then the rotating assembly will need to be balanced, after that I still have to determine the head gasket to be used, and then acquire an appropriate clutch/flywheel setup. Once that is done I will be ready to move on to getting the linkage built for the throttle bodies and figuring out how to use Motec, not to mention figuring out a coil pack setup to use. And of course I have to figure out the proper pump to use with the drysump pan, pulley setup, etc.
The GT transmission needs to be fitted with a pump and cooler and probably have the PSD swapped for an LSD.
I spent a few years just acquiring the parts I have, and it is daunting to always feel like there is so much more to do. I won't live in the garage, and always have to support (both fund wise and time wise) my other money pits, including my '90 GT street car, my '96 M3 street/track car, my R1, RX1 and now Grizzly.
I am not complaining, but the race car has definitely not had priority for quite some time.
- 928mac
- Moderator
Their kit has the coil that replaces the distributor system with all new wiring.
- srshaw3
928mac;888 wrote: Stan about the motec. Is that the same system that 928 ms uses for their kit.
I took a quick look at that site, and I see a TEC option, not the same as MoTec ( www.motec.com.au/ ).
Perhaps parts of their kit could be used, I don't know. I think the Don Hanson built race car used Motec and believe it moved close to me recently, so perhaps I can copy that work.
- 928mac
- Moderator
Stan.Shaw@Excell.Net;889 wrote: I took a quick look at that site, and I see a TEC option, not the same as MoTec ( www.motec.com.au/ ).
did you see this page
www.928motorsports.com/parts/tec_gt_engi...ement.php#enthusiast
- 928mac
- Moderator
This is a very interesting read for Hot Rodding your 928
forums.rennlist.com/rennforums/928-forum...r-the-32v-928-a.html
- srshaw3
928mac;891 wrote: did you see this page
Yes, but not sure they will work with my setup, once I investigate what I need, I may be able to put together a more cost effective solution.
- srshaw3
928mac;892 wrote: Carl has shared some of his research on this thread.
a couple pf photos of the tbi setup waiting for installation in my case
Attached files [img]media/attachments/894=82-928_051118_tbi_1.jpg[/img] [img]media/attachments/894=83-928_051118_tbi_2.jpg[/img]
- 928mac
- Moderator
Carl was talking about a set that he has designed.
They are to flow 360cfm so that he can build 800 ponys
some of his pictures are on that renn link
- srshaw3
928mac;895 wrote: wow that looks sweet Stan.
My vague recollection is that these are 52mm TBs.
I also have reworked S4 heads with custom cams.
- OBehave
- Moderator
- srshaw3
OBehave;954 wrote: I have the 52mm throttle bodies and B1 cams w/Motec.The heads are 3r's w/968 valves and ported w/Devek headers. Do you have the adapter/mounting plates for the throttle bodies Stan?
Yes, they are mounted to the throttle bodies in those photos.
As I recall my heads are 3R as well, ported with 968 valves. I have the 928 Int'l group buy Tri Y headers.
- OBehave
- Moderator
- adminVB
OBehave;1072 wrote: My headers are Devek level II with an X merge into a single, giant 4" tube exhaust and a small case Borla.I can't wait to get it running,I bet it sounds like WAR!
Keep in mind Lime Rock's very restrictive DB levels if you plan on running it there. Watkins Glen is unrestricted as I recall.
- OBehave
- Moderator
admin;1082 wrote: Watkins Glen is unrestricted as I recall.
Now you tell me!
