- Thank you received: 10
Bought another 928
- Kiln_Red
- Moderator
- 928mac
- Moderator
Have you posted a picture of it yet?
- Kiln_Red
- Moderator
- xstepson
- Premium Member
Did you check the connections in the spare tire well? The speedo sensor wires come up through there and there is a connection that has a possibility of corrosion.
stepson;10378 wrote: Austin,
I need to check this on my '95... Thanks for that info John, I forgot that is where the wires come through!
- Kiln_Red
- Moderator
Yes. I checked that plug first I think. I didn't visually see anything questionable about the connection. Later in my search, I measured voltage across plug H1 and H2. A helper then rolled it forward so that I could see the circuit pulsate.
- Kiln_Red
- Moderator
Here's a shot of the nose in front of my house. A little dark but you get the idea.
Fixed the Speedo thanks to Dwayne's writeup. Had to solder the rivets from the inside of the flexible PCB where it meets the Speedo circuit board. Also, got the electric cooling fan working; bad relay was all. It can be kind of hard getting in and out of gear. I tried the intermediate plate adjustment. Didn't seem to make much difference. Perhaps I didn't do it quite right. May try it again when I find the time...
- 928mac
- Moderator
- Kiln_Red
- Moderator
There's a rather rough early car floating around town here I see every once in a while. It's a royal blue with a ROUGH tan interior. Still sporting phone dials too. Still yet, I find it cool as it is still a 928. I'm sure it's still fun to drive too!
- 928mac
- Moderator
KilnRed;10552 wrote: I get a chubby any time I see a 928 of any MY, condition, or color!!
Ha ha ha I love that post of yours.
I needed a break from the election crowd, LOL
I hope you go for a good rip tonight Austin, just for me, with the window down :rolleyes:
- Kiln_Red
- Moderator
928mac;10814 wrote: Ha ha ha I love that post of yours.
I wish my car was not broke, and worse yet I wish I wasn't in the middle of a reno so I could start working on it.
Will do, good sir!!
- Kiln_Red
- Moderator
- OBehave
- Moderator
By the way, could you rotate that picture? My neck is killing me!
- Kiln_Red
- Moderator
- 928mac
- Moderator
- Jon B.
- Senior Member
I may end up buying another as a DD once I get home from deployment. There is a "nice" '86.5 in FL that I've had my eye on for a while.
- Kiln_Red
- Moderator
- Kiln_Red
- Moderator
pcar928fan;10846 wrote: Very nice Austin! You can't just have ONE 928!!! They are so affordable (to at least get in to) that is you know what you are doing you can get one cheap, do the little stuff yourself and have a hell of a fun car for very little money (relatively speaking!) YMMV!
Isn't that the truth, James! I don't have 10 yet but 4 should suffice for now.
KilnRed;10848 wrote: Isn't that the truth, James! I don't have 10 yet but 4 should suffice for now.
Austin,
That is a GREAT start my friend!
- OBehave
- Moderator
- curtisr
Lamborghini's director of marketing likens an all-black car to a very 'mysterious widow'. Not sure exactly what that means but, it sounds kinda intriguing.
Roger 'I've been too busy with my 924s to write much here but loves his 928 bestest' Curtis
- emmanuelli
- Elite Member
- Kiln_Red
- Moderator
curtisr;10925 wrote: Black is beautiful! While my wife prefers that we keep our 928 the silver it is, my preference would be to sneak out and return with a gloss-black paint job.
Interesting info, Curtis! Black is always my first choice on a sports car. It likely won't be a keeper, though, ultimately. I bought it to drive and catch up some maintenance duties. One day, I'd like to have a black S4 or GT.
Realistically, I will probably sell it and use the funds to eventually complete my kiln red '84 auto. It's been under going a mini restoration but I haven't had much opportunity to work on it recently.
emmanuelli;11056 wrote: that looks pretty nice!
Thank you!
- 928mac
- Moderator
KilnRed;10817 wrote: Btw Brad, here is a better photo. Would like to update wheels & tires and leave the '84 to look all original.
Sorry I didn't answer sooner Austin
Yes I like the cup style wheels better then the disk and I also like the stock look of my S4 with the wing on the back. So you could just leave your car stock looking.
I would say to go with your taste.
For me I only change things that I could put back. I have the turbo twist wheels on the car now.
If I bought a stock [engine LH and EZK] wiring harness, I could return it to the stock system.
The only mod I did that can not be reversed is that I ported the heads and gasket matched it to the intake, so that means the intake was hogged out as well
