Rear Tail Light Screw Washer
- babromovage
31 Jan 2012 04:47 #8008
by babromovage
Rear Tail Light Screw Washer was created by babromovage
There are small rubber washer that the screws set into to secure the rear taillight lense to the tail light housing. Most likely prevents water or moisture from getting behind the lense. Does anyone know when I can find these?
Thank You,
Thank You,
- srshaw3
31 Jan 2012 05:07 #8009
This is where the 928 venders are wonderful, they will know, 928gt.com, 928intl.com or 928srus.com (in alpha order).
Replied by srshaw3 on topic Rear Tail Light Screw Washer
babromovage;8180 wrote: There are small rubber washer that the screws set into to secure the rear taillight lense to the tail light housing. Most likely prevents water or moisture from getting behind the lense. Does anyone know when I can find these?
Thank You,
Moderators: Rich928, billvvOC
